[mapguide-users] Maestro and Nulls
David Bowen dbowenrci at gmail.com
Fri Jan 31 07:49:32 PST 2025
Hi Jackie,
We're encountering an issue where data is not showing up on the map when a
filter, under Layer Settings, is used and the attribute is null. For
example, if the filter is COUNTRY <> 'CANADA' any record that does not
contain a country will not show up on the map.
We're using composite styles for this specific layer and our database is
Oracle.
Thanks,
David
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20250131/632155e7/attachment.htm>
