[mapguide-users] Help required following up on a FDO PostgreSQL provider bug
Ari Hyvönen ari.hyvonen at gmail.com
Wed Jul 16 07:44:50 PDT 2025
Creating these two will trigger issue. Materialized views can be in public
schema.
Create materialized view mv_test1 as select 1 as foo;
Create materialized view mv_test2 as select 2 as foo;
Br, Ari
ke 16. heinäk. 2025 klo 16.10 Jackie Ng via mapguide-users <
mapguide-users at lists.osgeo.org> kirjoitti:
> Hi All,
> I had some time available to follow up on this FDO bug:
> https://trac.osgeo.org/fdo/ticket/1003
> However, I am unable to write a failing provider unit test case that can
> trigger this problem. The biggest issue is that I do not have a reference
> database structure that I can write this test against. The hypothetical
> database structures that I came up with could not reproduce this issue.
> My tests so far have been using FDO IDescribeSchema with and without
> schema/class name filters and verifying that materialized views from other
> schemas do not bleed into the schema I am describing, which so far is
> always the case.
> To whomever is afflicted with this issue, I *require* a minimal database
> structure (the CREATE SCHEMA/TABLE/VIEW statements to make this db) and
> also ideally steps to reproduce the problem in MapGuide or a FDO client
> application like FDO Toolbox.
> I will give this ticket 1-2 weeks to live. If I do not receive anything
> actionable by then, I will close this ticket as I cannot reproduce the
> problem. While I might theoretically know how to fix this issue, I do not
> apply theoretical bug fixes. I always want concrete examples to confirm
> such issues before fixing them.
> - Jackie
> mapguide-users mailing list
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20250716/9594773d/attachment.htm>
