[mapguide-users] Bing Maps v6/7 API Deprecated – Error_Fusion_BingMapsMissingApiKey in MapGuide
    Scott Hameister
    flipper at buoyshark.com
    Fri Jul 18 10:10:24 PDT 2025
If you have an azure maps key, you can consume them as XYZ tiles. Make sure
to set the CORS policy in Azure because the Key is visible in the request
On Fri, Jul 18, 2025 at 12:08 AM Nimrod Cnaan via mapguide-users <
mapguide-users at lists.osgeo.org> wrote:
> Hi all,
> Just a heads-up for anyone still using Bing Maps as a background layer in
> their MapGuide applications:
> As from yesterday* the Bing Maps v6 and v7 APIs* by Microsoft versions
> are no longer supported, and as a result, map tiles fail to load unless a
> valid API key is provided using the newer endpoints.
> What this means:
>    If you're using Fusion templates that rely on Bing Maps layers, and
>    you see Error_Fusion_BingMapsMissingApiKey in the viewer or logs, it's
>    likely due to this deprecation.
>    Fusion’s default configuration for Bing Maps may still refer to the
>    older API structure, which no longer functions without updates.
> Suggested Actions:
>    1.
>    *Update Your Fusion Widgets*: Make sure your BingMaps widget
>    configuration is pointing to a supported Bing Maps API version.
>    2.
>    *Switch to Alternative Background Layers*: If you prefer not to deal
>    with Bing Maps licensing, consider switching to OpenStreetMap or other tile
>    providers (Stamen, Mapbox, etc.).
> If anyone has already patched Fusion or MapGuide configurations to work
> with the newer Azure Maps API or other tile providers, feel free to share
> your approach with the list.
> Hope this helps others avoid issuse!
> Best regards,
> Nimrod Cnaan
> בכבוד רב,
> *נמרוד כנען**   |   *גיאומינד שירותי GIS  –  פיתוח,  ייעוץ  ושירותי ענן
> ישיר: 048101268 | נייד: 0525355483 | nimrod at geomind.co.il
> נא בקרו באתר החדש שלנו http://geomind.co.il
> mapguide-users mailing list
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20250718/d7288fac/attachment.htm>
