[mapguide-users] Issue with External Map Alignment in Version 14.10
Nimrod Cnaan nimcnaan at gmail.com
Mon Mar 3 04:22:20 PST 2025
Hello everyone,
> In previous version of *MapGuide-React-Viewer 0.14.2*, there was an
> option to influence the position of the *external base map* by setting
> the following in the *LAYOUT *to be compatible with the: (for example)
> <projection>EPSG:2039</projection>
> With this setting, the external map aligned correctly with the map & base
> map local coordinate\EPSG.
> This option doesn't seem to be working for the new version 0.14.10, it
> seems there is no effect on the External Base Map's positioning, and there
> is a misalignment between local layers and the external map background (See
> attached pic). This creates an issue where the alignment between the map
> and the data layers does not match.
> We are aware that changing the *Map *projection to *EPSG:900913* resolves
> the shifting issue, but this introduces a problem with the map's coordinate
> grid, and some of our clients are not willing to work with this coordinate
> system.
> Is there a way to work around this issue in version 0.14.10?
> Looking forward to your thoughts and potential solutions.
> Thank you in advance!
> Nimrod Cnaan
בכבוד רב,
*נמרוד כנען**   |   *גיאומינד שירותי GIS  –  פיתוח,  ייעוץ  ושירותי ענן
ישיר: 048101268 | נייד: 0525355483 | nimrod at geomind.co.il
נא בקרו באתר החדש שלנו http://geomind.co.il
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20250303/3d95aa4f/attachment.htm>
