[mapguide-users] Issue with External Map Alignment in Version 14.10
Nimrod Cnaan nimcnaan at gmail.com
Sat Mar 8 10:48:28 PST 2025
במקרה כזה, כדאי להסביר את המצב הזה למנהל הפרויקט ולהציע חלופות אפשריות. הנה
הצעה לתגובה שתוכל לשלוח:
Hello,
Thank you for your response.
Unfortunately, I am unable to test previous versions (0.14.3 to 0.14.9) due
to a change in EPSG support: the EPSG.io API endpoints, which we rely on
for the EPSG:2039 projection,
was deprecated on 01/02/25. As a result, these endpoints are no longer
functional for me.
Given this limitation, is there an alternative way to troubleshoot this
issue?
Would sharing my LAYOUT configuration help in diagnosing the issue?
I appreciate your help and any guidance you can provide.
Thank you in advance!
Best regards,
Nimrod Cnaan
ההודעה הזו מסבירה את המגבלות שלך בצורה ברורה ומבקשת הצעות לפתרון חלופי. אם
תרצה לערוך או להוסיף משהו, רק תגיד! 😊
‫בתאריך יום ג׳, 4 במרץ 2025 ב-12:08 מאת ‪Jackie Ng via mapguide-users‬‏ <‪
mapguide-users at lists.osgeo.org‬‏>:‬
> For starters, if something worked in 0.14.2 and "broke" in 0.14.10 can you
> at least download all the releases in between (0.14.3, 0.14.4, ... 0.14.9)
> and identify the first release where this stopped working. That will at
> least help us narrow down the series of changes.
> - Jackie
> You wrote:
> Hello everyone,
> In previous version of *MapGuide-React-Viewer 0.14.2*, there was an
> option to influence the position of the *external base map* by setting
> the following in the *LAYOUT *to be compatible with the: (for example)
> <projection>EPSG:2039</projection>
> With this setting, the external map aligned correctly with the map & base
> map local coordinate\EPSG.
> This option doesn't seem to be working for the new version 0.14.10, it
> seems there is no effect on the External Base Map's positioning, and there
> is a misalignment between local layers and the external map background (See
> attached pic). This creates an issue where the alignment between the map
> and the data layers does not match.
> We are aware that changing the *Map *projection to *EPSG:900913* resolves
> the shifting issue, but this introduces a problem with the map's coordinate
> grid, and some of our clients are not willing to work with this coordinate
> system.
> Is there a way to work around this issue in version 0.14.10?
> Looking forward to your thoughts and potential solutions.
> mapguide-users mailing list
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
בכבוד רב,
*נמרוד כנען**   |   *גיאומינד שירותי GIS  –  פיתוח,  ייעוץ  ושירותי ענן
ישיר: 048101268 | נייד: 0525355483 | nimrod at geomind.co.il
נא בקרו באתר החדש שלנו http://geomind.co.il
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20250308/f3d95e75/attachment.htm>
