[mapguide-users] MGOS 4 Beta 2 and CodeIgniter
Gordon Luckett
gordon.luckett at arrowgeomatics.com
Wed Nov 12 08:05:05 PST 2025
Hi David
When in doubt, I use Jackie's Sanity Check..
https://themapguyde.blogspot.com/2022/04/mapguide-dev-diary-important.html?m=1
On Wed, 12 Nov 2025, 10:39 David Bowen via mapguide-users, <
mapguide-users at lists.osgeo.org> wrote:
> Our application is built using the Model/View/Controller (MVC) framework
> CodeIgniter and I'm attempting to update the MVC framework from v3.1.13 to
> v4.6.3, but I'm encountering an issue where it seems that one of the
> MapGuide functions isn’t being loaded or recognized. The issue occurs
> during the log out process, where a user logs out of the application and
> there's a series of steps that take place to destroy the sessions (code
> below).
> I'm getting the following error when I attempt to log out of the
> application: Call to undefined function
> App\Controllers\Login\MgUserInformation(). This function,
> MgUserInformation, is successfully called when the user first logs into the
> application and a session is created, so I’m unclear what’s causing the
> issue.
> Does anyone have familiarity with MGOS and CodeIgniter 4, or would anyone
> have suggestions on how to check if MGOS functions are being properly
> loaded?
> We're running MGOS 4 Beta 2 and are unable to go to MGOS 4 until we've
> updated the MCV framework.
> Thanks,
> David
> function logout() {
> //Log out and destroy session
> $this->mgExtDir = getenv('mg_extensionsDir');
> $this->webconfig_ini = getenv( 'webconfigFilePath' );
> $this->mgMapID = $this->_getValueByFieldName( 'MAPNAME' );
> $this->mgSessionId = $this->_getValueByFieldName( 'SESSION' );
> try {
> // Initialize the Web Extensions and connect to the Server using
> // the Web Extensions session identifier stored in PHP session
> state.
> MgInitializeWebTier( $this->webconfig_ini );
> $si = $this->mgSessionId;
> // code fails on following line
> $userInfo = new MgUserInformation( $this->mgSessionId );
> $siteConnection = new MgSiteConnection();
> $siteConnection->Open( $userInfo );
> $siteConnection->GetSite()->DestroySession( $this->mgSessionId );
> } catch ( MgException $e ) {
> echo $e->GetMessage();
> echo $e->GetDetails();
> $session_dat = array( 'logged_in' => FALSE );
> session()->set( $session_dat );
> session()->destroy();
> return redirect()->to( 'login/login' ); //Direct user back to login
> screen
> mapguide-users mailing list
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20251112/1e9ac8e0/attachment.htm>
