[mapguide-users] MGOS 4 Final Release and GetLayers
Gordon Luckett
gordon.luckett at arrowgeomatics.com
Thu May 28 06:15:08 PDT 2026
I would be curious about the line:
$this->MapGuideObject->getMap();
Share this definition?
On Mon, May 25, 2026 at 1:35 PM David Bowen via mapguide-users <
mapguide-users at lists.osgeo.org> wrote:
> We're updating our application from using an MVC framework to being a PHP
> only application. We're getting an unexpected error when running a spatial
> query that looks for corresponding data, from a specified layer, that falls
> within a set distance of the geocoded coordinates. This function worked as
> expected in the MVC framework and the only code change, for this section of
> code, is how the MG_initialize library is loaded.
> Going through the function step-by-step, it appears that it's failing when
> it attempts to retrieve the layers from MapGuide. Instead of returning
> something, it's returning NULL. This triggers a Fusion error, where 1 of 2
> different error messages are displayed.
> The first error message is:
> Failed to retrieve message for "MgFileNotFoundException". Failed to
> retrieve message for "MgFileIoErrNo". - MgInitializeWebTier line 155 file
> C:\Workspace\mg-4.0\MgDev\Web\src\WebSupport\InitializeWebTier.cpp -
> MgInitializeWebTierInternal line 116 file
> MgResources.LoadResources line 388 file
> C:\Workspace\mg-4.0\MgDev\Common\Foundation\System\Resources.cpp -
> MgResources.ParseFile line 632 file
> ByteSourceFileImpl.LoadFile line 127 file
> C:\Workspace\mg-4.0\MgDev\Common\Foundation\System\ByteSourceFileImpl.cpp
> The second error message is:
> Fatal error: Uncaught TypeError: extract(): Argument #1 ($array) must be
> of type array, string given in PATH\map\view\page.php:116 Stack trace: #0
> PATH\map\view\page.php(116): extract() #1
> PATH\maptools\sel_action.php(154): require_once('...') #2
> PATH\maptools\sel_action.php(56): Sel_Action->selectionReport_ql() #3
> PATH\maptools\sel_action.php(290): Sel_Action->__construct() #4 {main}
> thrown in PATH\map\view\page.php on line 116
> The script is:
> function __construct( $config ) {
> $mapName = $config[ 'mapname' ];
> $mgSessionID = $config[ 'mapsession' ];
> $this->mgMapID = $mapName;
> $this->mgSessionId = $mgSessionID;
> //Initialize a MapGuide object instance
> require_once('../library/mapguide/Mg_initialize.php');
> $this->MapGuideObject = new Mg_initialize();
> $this->MapGuideObject->init( $this->mgMapID, $this->mgSessionId );
> function getSelection() {
> $myMap = $this->MapGuideObject->getMap();
> $session = $this->mgSessionId;
> $mapName = $this->mgMapID;
> $objkeys = '';
> $errorMsg = null;
> $siteConnection = $this->MapGuideObject->getSiteConnection();
> // Get an instance of the Resource and Mapping Services and use
> them to open the map and initialize a selection object.
> $resourceSrvc = $this->MapGuideObject->getResourceService();
> $featureSrvc = $this->MapGuideObject->getFeatureService();
> //Get selected map layers.
> $sel = new MgSelection( $myMap );
> $sel->Open( $resourceSrvc, $mapName );
> $this->originalSel = $sel->ToXml();
> // this is where it appears to fail
> $selLayers = $sel->GetLayers();
> //script continues but likely not relevant
> Any input would be greatly appreciated.
> mapguide-users mailing list
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20260528/1727eb53/attachment.htm>
