[mapguide-dev] problems initializing web tier
alucas at srtec.com
alucas at srtec.com
Mon Apr 24 08:39:33 EDT 2006
Hi Traian,
I was thinking this, for this reason, I was put all dll's generated with
WebTier.sln in the same directory that exe file. So, the directory
contains:
ACE.dll
All Api dll's : MapGuideJavaApi.dll ...
MapguideUnmanagedApi.dll
MgCommon.dll
MgCoordinateSystem.dll
I don't know nothing about dependency tool. I never have used it. I will
search in the net.
> Could it be that it is looking for the dll that contains
> MgInitializeWebTier (or one of its dependencies) and not finding it? Do
> you have the dependency tool (depends.exe). Could you run it against
> MapGuideDotNetApid.dll and see which dlls it depends on and is not
> finding?
> For example, when you add a managed dependency, if that dll has
> unmanaged dependencies (like MgCommond.dll in our case), the unmanaged
> dependencies will not get automatically copied to the .exe directory and
> you will need to do it by hand.
> Traian
> -----Original Message-----
> From: alucas at srtec.com [mailto:alucas at srtec.com]
> Sent: Monday, April 24, 2006 7:18 AM
> To: dev at mapguide.osgeo.org
> Subject: [mapguide-dev] problems initializing web tier
> Hello list,
> When I try to connect to the server in .NET, I get the exception:
> 'An unhandled exception of type 'OSGeo.MapGuide.MgFileNotFoundException'
> occurred in MapGuideDotNetApid.dll'
> I've added as a reference 'MapGuideDotNetApi.dll' in the project.
> The sample code to establish my conenction is:
> // This is a sample windows form application in C#.
> // I've tried with @"c:\pathtofile\webconfig.ini".
> // Here, the file is in the same directory that .exe
> // I've changed the IP address in the webconfig.ini
> // Here, I get the exception
> MapGuideApi.MgInitializeWebTier("webconfig.ini");
> // I've tried several paths and combinations but
> // always get the same exception.
> MgUserInformation userInfo = new
> MgUserInformation("Administrator","admin");
> MgSiteConnection siteConn = new MgSiteConnection();
> siteConn.Open(userInfo);
> Antonio Lucas
> Software Engineer
> SER&TEC S.L
> Phone: +34 96 395 95 13
> www.srtec.com
> Valencia (Spain)
> To unsubscribe, e-mail: dev-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: dev-help at mapguide.osgeo.org
Antonio Lucas
Software Engineer
SER&TEC S.L
www.srtec.com
Valencia (Spain)
More information about the Mapguide_dev
