[mapguide-dev] problem with tcp port
"Antonio Lucas Rodríguez (sr&tec)" alucas at srtec.com
Thu Apr 27 09:51:21 EDT 2006
Traian Stanev wrote:
>Have you tried calling other service functions and have they worked? For
>example try calling ResourceService::EnumerateResources. If that returns
>a bunch of XML then the server is working ok and the issue is likely
>with RenderMap. Also, can you look at what is in the MgMap object that
>you pass in to RenderMap. What is the map scale, display width and
>height, dpi, data extents, etc? If these are bad values, you may get
>errors with RenderMap.
>Traian
>-----Original Message-----
>From: alucas at srtec.com [mailto:alucas at srtec.com]
>Sent: Wednesday, April 26, 2006 7:13 PM
>To: dev at mapguide.osgeo.org
>Subject: [mapguide-dev] problem with tcp port
>Hello,
>I've a problem. I'm writting a sample desktop c# application that render
>a
>map located in a server. All works fine, but when I call renderMap
>method,
>I get a error with the port for connection 2801 in the server and the
>MapGuideServer service in the server machine crash.
>Sample code:(Sorry for long lines of code, I'm wrtting from web mail)
>// Init Winsock
>MapGuideApi.InitializeSockets();
>// Init WebTier
>MapGuideApi.MgInitializeWebTier(@"C:\Program
>Files\MapGuideOpenSource\WebServerExtensions\www\webconfig.ini");
>// Connect to the site server
>MgSiteConnection siteConn = new MgSiteConnection();
>MgUserInformation userInfo = new
>MgUserInformation("Administrator","admin");
>siteConn.Open(userInfo);
>// create an instance of resource service
>MgResourceService
>resourceService=siteConn.CreateService(MgServiceType.ResourceService)as
>MgResourceService;
>MgRenderingService renderService =
>siteConn.CreateService(MgServiceType.RenderingService) as
>MgRenderingService;
>MgResourceIdentifier resourceMap = new
>MgResourceIdentifier("Library://Samples/test/Map/Map.MapDefinition");
>// Create a new map instance
>MgMap map = new MgMap();
>map.Create(resourceService, resourceMap, "Map");
>// Render the map (for test to show map features, it works fine)
>//MgEnvelope ext = map.GetMapExtent();
>//MgCoordinate ll = ext.GetLowerLeftCoordinate();
>//MgCoordinate ur = ext.GetUpperRightCoordinate();
>//string bgcolor = map.GetBackgroundColor();
>// MessageBox.Show(bgcolor); // works fine
>// problem writting protected memory!!!
>MgByteReader rdr = renderService.RenderMap(map, null, "png");
>Future steps when I've solved this problem:
>//MgByteSink bs = new MgByteSink(rdr);
>//bs.ToFile("demo.png");
>In the server side, I went to logs dir. and open Errors file and this is
>the error reported:
><2006-04-25T21:43:25>
> Error: Port 2801 is not available, please try using a different port.
>        Exception occurred in method MgServer.svc at line 1001 in file
>c:\build_tux_area\mgdev\server\src\core\Server.cpp
>I've tested the port in the server with a sample tcp program that
>connects
>to server:2801 and the server and port are ok. The client application
>show
>a error writting in protected memory...
>In my webconfig, I think that all is ok, this config file is in my
>client
>machine (where c# app runs). So, I suspect that port 2801 is for
>connections from server side applications. I suspect this, because
>reading
>the webconfig file, in the statement 'client connection' only the port
>is
>specified, but in 'site connections' exists IP and port. I'm not sure of
>this.
>Any idea?
>Thanks in advance.
>Antonio Lucas
>Software Engineer
>SER&TEC S.L
>Phone: +34 96 395 95 13
>www.srtec.com
>Valencia (Spain)
>To unsubscribe, e-mail: dev-unsubscribe at mapguide.osgeo.org
>For additional commands, e-mail: dev-help at mapguide.osgeo.org
Hi Traian,
I will try to connect with other services. I've displayed values of map
like extensions: coordinates, bgcolor, etc and all works fine, despite I
will attempt to display more values and send this values to the list.
Thanks.
Antonio Lucas
Software Engineer
alucas at srtec.com <mailto:alucas at srtec.com> 	www.srtec.com
<http://www.srtec.com>
963·959·513
Fax 963·731·756
	  	SER&TEC
avda. Ausias March 79 - 1
46013 Valencia
Skipped content of type multipart/related
More information about the Mapguide_dev mailing list
