Roadblock trying to build from SVN with VS2005...
Jason Birch Jason.Birch at nanaimo.ca
Fri Aug 25 16:12:51 EDT 2006
Has the build order changed with the introduction of the common
framework, or is there an additional environment variable or VS setting
that I need to have?
When I try to build Oem (the first step in the docs) I get an error in
the SQLite compilation:
Error	1	fatal error C1083: Cannot open include file:
'MapGuideCommon.h': No such file or directory
d:\osgeo\mgbuild\oem\sqlite\src\sqlitephpapi\sqlitephpapi_wrap.cpp
62
Jason
More information about the Mapguide_dev mailing list
