[mapguide-dev] area calculation conversion to meters
Paul Spencer
pspencer at dmsolutions.ca
Mon Dec 4 11:06:15 EST 2006
Sweet, thanks Daniel. Can you confirm something for me please? In
the sprintf, there is a zoneStr variable that appears to have no
value and perhaps shouldn't be there? As far as I can see, there are
only two substitution points in the string and zoneStr shouldn't go
in either one :)
Cheers
Paul
On 4-Dec-06, at 10:55 AM, Daniel Morissette wrote:
> Paul Spencer wrote:
>> over my head, for sure! I don't think I need that kind of
>> accuracy. I would like to know if there is a programmatic way to
>> determine a UTM coordinate system centered on a particular
>> location or, as a minimum, a way to find the UTM zone that a given
>> coordinate lies in.
>> Is there some base string I could use and just substitute in some
>> values?
> The OGC WMS spec has projection AUTO:42001 that does that. There
> used to be some background info including some code snippets
> showing how to setup a UTM coordsys centered on a given location/
> zone at http://www.digitalearth.gov/wmt/auto.html but this page has
> been taken down a little while ago.
> Thanks to the Web Archive, you can still find the info here:
> http://web.archive.org/web/20010430015937/http://
> The block of code you're looking for is:
> /** WGS 84 / Auto UTM **/
> zone = floor( (lon0 + 180.0) / 6.0 ) + 1;
> sprintf( wktStr, "PROJCS[\"WGS 84 / Auto UTM\",GEOGCS[\"WGS
> 84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS_1984\",
> 6378137,298.257223563]],PRIMEM[\"Greenwich\",0],UNIT
> [\"Decimal_Degree\",0.0174532925199433]],PROJECTION
> [\"Transverse_Mercator\"],PARAMETER[\"central_meridian\",%.
> 16g],PARAMETER[\"latitude_of_origin\",0],PARAMETER[\"scale_factor\",
> 0.9996],PARAMETER[\"false_easting\",500000],PARAMETER
> [\"false_northing\",%.16g],UNIT[\"Meter\",1]]", zoneStr, -183.0 +
> zone * 6.0, (lat0 >= 0.0) ? 0.0 : 10000000.0 );
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
> To unsubscribe, e-mail: dev-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: dev-help at mapguide.osgeo.org
|Paul Spencer pspencer at dmsolutions.ca |
|Chief Technology Officer |
|DM Solutions Group Inc http://www.dmsolutions.ca/ |
More information about the Mapguide_dev
