[mapguide-dev] PHP pages for describing a feature source RFC
Jason Birch Jason.Birch at nanaimo.ca
Wed Dec 13 13:31:57 EST 2006
Honestly, I'm not sure about the technical details.
Bob said something at AU about the WMS parameters being stored in the
metadata element of the resource header, but I could be a bit fuzzy on
that.  Basically, I'd like to be able to see:
- The WMS parameters for WMS feature sources
- The image catalog definition for Raster feature sources (such as those
converted from 6.5 RIC files)
Jason
From: Rex Szeto (Intern) [mailto:Rex.Szeto at autodesk.com]
Sent: Wednesday, December 13, 2006 10:27
To: dev at mapguide.osgeo.org
Subject: RE: [mapguide-dev] PHP pages for describing a feature source
RFC
Hi Jason,
Yes, the scripts for this will be in another directory with the same
level as the mapagent/* and mapadmin/*. I'll make changes on the RFC to
specify this.
As for the contents of the resource header, can you clarify as to what
you are looking for?
I performed a GetResourceHeader on a Raster feature source in the
mapagent and got back the information:
  <?xml version="1.0" encoding="utf-8" ?>
- <ResourceDocumentHeader
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="ResourceDocumentHeader-1.0.0.xsd">
  - <General>
      <IconName>FeatureSourceRasterAtil</IconName>
    </General>
  - <Security
xsi:noNamespaceSchemaLocation="ResourceSecurity-1.0.0.xsd">
      <Inherited>true</Inherited>
    </Security>
  </ResourceDocumentHeader>
Thanks,
Rex
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Tuesday, December 12, 2006 2:03 PM
RFC
Cool idea.  I really like the idea of doing this as a generic feature
that can be used by either Studio or Web Studio.
I'm a little at a loss on where these will fit in.
- The php viewer won't always be installed
- The mapagent/*.(html|php) scripts will generally not be installed on
production machines
- The mapadmin/* scripts will typically be secured to the point where
accessing them from Studio or Web Studio may not be realistic.
Do we need a new location for generic server-side web scripts?
I would also like to be able to use these scripts to view the contents
of the resource header for the feature type, including any metadata
(resource metadata, not ISO or FGDC metadata).  This would help
understand feature types like Raster and WMS better.
Jason
Sent: Tuesday, December 12, 2006 12:30
Subject: [mapguide-dev] PHP pages for describing a feature source RFC
I have just posted a draft of the RFC for "PHP pages for describing a
feature source" in MGOS to the following location:
http://wiki.osgeo.org/index.php/MapGuide_RFC_8_-_PHP_pages_for_describin
g_a_feature_source
Please take a look, and post any feedback to this group.
Thanks,
Rex Szeto
URL: http://lists.osgeo.org/pipermail/mapguide_dev/attachments/20061213/32a044ad/attachment.html
More information about the Mapguide_dev mailing list
