[mapguide-dev] MGOS 1.1.0 Release
Jim O'Leary joleary.public at gmail.com
Mon Dec 18 16:37:36 EST 2006
I uninstalled 1.0.1 Server and Extensions and installed this release on my XP
machine. The install did not generate and errors and did create required
directories, but Apache did not start. It did not show in the Services, and
when I executed Apache.exe from the command line in Apache2\bin, the error
message said:
C:\Program Files\MapGuideOpenSource\WebServerExtensions\Apache2\bin>apache
(OS 10048)Only one usage of each socket address (protocol/network
address/port)
is normally permitted.  : make_sock: could not bind to address 0.0.0.0:8008
no listening sockets available, shutting down
Unable to open logs
I changed http.conf to read:
Listen 8009
and now it works. What is going on? I would like to go back to port 8008.
Thanks
Tom Fukushima wrote:
> Hi,
> Barring any problems we are planning to release MG 1.1.0 this coming
> weekend (Dec 16th).  If there are any issues that you are aware of,
> please reply to this mailing list.
> Thanks
> Tom
View this message in context: http://www.nabble.com/MGOS-1.1.0-Release-tf2803698.html#a7937071
Sent from the MapGuide Dev mailing list archive at Nabble.com.
More information about the Mapguide_dev mailing list
