[mapguide-dev] PHP pages for describing a feature source RFC
Tom Fukushima
tom.fukushima at autodesk.com
Tue Dec 19 13:51:29 EST 2006
Thanks Burce, but unfortunately in this case those schemas will not
help:
* the Raster Provider configuration document schema is not stored at
that location.
* the WMS data stored in the headers is stored as "free form" strings so
the corresponding schema (ResourceDocumentHeader-1.0.0.xsd) will not
help.
Tom
_____
Sent: Tuesday, December 19, 2006 11:30 AM
To: dev at mapguide.osgeo.org
Subject: RE: [mapguide-dev] PHP pages for describing a feature source
RFC
Jason,
The schemas used by MapGuide are available here in the source tree:
..\MgDev\OS\Common\Schema
Or here if you have installed MapGuide:
Open Source: C:\Program Files\MapGuideOpenSource\Server\Schema
Enterprise: C:\Program
Files\Autodesk\MapGuideEnterprise2007\Server\Schema
Thanks,
Bruce
_____
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: December 19, 2006 11:15 AM
RFC
Thanks Tom,
As long as this repository insight tool is built in an easily extensible
manner, I won't have any problem voting +1 on the RFP as it stands.
It looks like adding these items is just a matter of doing an XSLT
transform on an XML fragment. If so, that might be something I can play
around with in my "spare" time once the initial implementation is in
place. I'll have to pester people for the schemas unless they're
already included somewhere in the source tree.
Hopefully as the project matures, we will start getting these
enhancement proposals into the RFP process earlier. Perhaps we should
also look at some level of abstraction for large features, so that
implementation can be phased across several RFPs but tracked as a part
of a set of related features? This idea is already in the roadmap, but
a bit more ad-hoc.
Jason
_____
Sent: Tuesday, December 19, 2006 09:20
RFC
Hi Jason,
These are good ideas. Unfortunately, after some investigation, it looks
like these will require a little more effort than we have available
right now. The good news is that these things can be seemlessly added
later. If anyone else wants to do this, I'm sure a MapGuide developer
can help with meta data storage formats, and an FDO developer could help
with the Raster config schema.
Tom
_____
Sent: Wednesday, December 13, 2006 11:32 AM
RFC
Honestly, I'm not sure about the technical details.
Bob said something at AU about the WMS parameters being stored in the
metadata element of the resource header, but I could be a bit fuzzy on
that. Basically, I'd like to be able to see:
- The WMS parameters for WMS feature sources
- The image catalog definition for Raster feature sources (such as those
converted from 6.5 RIC files)
Jason
_____
Sent: Wednesday, December 13, 2006 10:27
RFC
Hi Jason,
Yes, the scripts for this will be in another directory with the same
level as the mapagent/* and mapadmin/*. I'll make changes on the RFC to
specify this.
As for the contents of the resource header, can you clarify as to what
you are looking for?
I performed a GetResourceHeader on a Raster feature source in the
mapagent and got back the information:
<?xml version="1.0" encoding="utf-8" ?>
- <ResourceDocumentHeader
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="ResourceDocumentHeader-1.0.0.xsd">
- <General>
<IconName>FeatureSourceRasterAtil</IconName>
</General>
- <Security
xsi:noNamespaceSchemaLocation="ResourceSecurity-1.0.0.xsd">
<Inherited>true</Inherited>
</Security>
</ResourceDocumentHeader>
Thanks,
Rex
_____
Sent: Tuesday, December 12, 2006 2:03 PM
RFC
Cool idea. I really like the idea of doing this as a generic feature
that can be used by either Studio or Web Studio.
I'm a little at a loss on where these will fit in.
- The php viewer won't always be installed
- The mapagent/*.(html|php) scripts will generally not be installed on
production machines
- The mapadmin/* scripts will typically be secured to the point where
accessing them from Studio or Web Studio may not be realistic.
Do we need a new location for generic server-side web scripts?
I would also like to be able to use these scripts to view the contents
of the resource header for the feature type, including any metadata
(resource metadata, not ISO or FGDC metadata). This would help
understand feature types like Raster and WMS better.
Jason
_____
Sent: Tuesday, December 12, 2006 12:30
Subject: [mapguide-dev] PHP pages for describing a feature source RFC
I have just posted a draft of the RFC for "PHP pages for describing a
feature source" in MGOS to the following location:
http://wiki.osgeo.org/index.php/MapGuide_RFC_8_-_PHP_pages_for_describin
g_a_feature_source
Please take a look, and post any feedback to this group.
Thanks,
Rex Szeto
URL: http://lists.osgeo.org/pipermail/mapguide_dev/attachments/20061219/fc5b9c07/attachment.html
More information about the Mapguide_dev
