[mapguide-dev] Subversion vaults offline over the holidays starting Dec 21st
Jason Birch
Jason.Birch at nanaimo.ca
Tue Dec 19 19:03:20 EST 2006
Will the domain name be changing?
If so, will we need to do anything to our client repositories to "move"
the data?
If not, we should be careful and make sure that we do not have locally
cached DNS results for the osgeo.org domain before submitting changes,
or they may accidentally go to CollabNet instead of the new location.
Jason
From: Tom Fukushima [mailto:tom.fukushima at autodesk.com]
Sent: Tuesday, December 19, 2006 15:58
To: dev at mapguide.osgeo.org
Subject: [mapguide-dev] Subversion vaults offline over the holidays
starting Dec 21st
Hi all,
The subversion vaults are being migrated off Collabnet to our new
provider, peer1, starting on Dec 21st and so should not be used until
they come back online at our new provider. You will get another email
when the new vaults are online.
Although the vaults may be available, no submissions should be made
because you may lose your work. If you want the latest code before the
holidays, the 21st is the day to do the last svn update.
Thanks
Tom
URL: http://lists.osgeo.org/pipermail/mapguide_dev/attachments/20061219/fa75ee0b/attachment.html
More information about the Mapguide_dev
