[mapguide-dev] How to call the load procedure from program???
Bill Dhimitri bill.dhimitri at autodesk.com
Mon Jul 10 13:04:02 EDT 2006
Hi Rasel,
MapGuide Studio provides an API that allows you to programmatically load
an SDF file.  Go to the Studio API Help, and look up (in the index) the
SdfLoadProcedure class.
Bill
  _____
[mailto:rasel.anawer at grameenphone.com]
Sent: Monday, July 10, 2006 7:49 AM
To: dev at mapguide.osgeo.org
Subject: [mapguide-dev] How to call the load procedure from program???
I have a load procedure which loads a SDF file and generate Data and
Layer only.
Please help and thanks in advance...
MD. RASEL ANAWER
System Engineer, TMN, TD,
GrameenPhone Ltd.
Mobile : +8801711506316
E-mail: rasel.anawer at grameenphone.com
This email and any files transmitted with it are confidential and
intended solely for the use of the individual or entity to which they
are addressed. It may also be legally privileged. If you are not the
named addressee, you should not copy, forward, disclose or use any part
of it. If you have received this message in error, please delete it and
all copies from your system and notify the sender immediately by return
e-mail. Internet communications cannot be guaranteed to be timely,
secure, error or virus-free. The sender does not accept liability for
any errors or omissions.
URL: http://lists.osgeo.org/pipermail/mapguide_dev/attachments/20060710/e97c4c4c/attachment.html
More information about the Mapguide_dev mailing list
