addind layers
Frédéric Lieto
flieto at geomapgis.com
Thu Jun 1 05:59:03 EDT 2006
I try to add a new xml layer in a layerout map.
A " $map->save " is necessary to make it visible in IE, but it only works in a session repositery. If I try to do the same in the Library, I have a parse xml error.
To avoid the problem, I try, just after the ->save to make a copyResource of the mapdefinition in another repositery. The new mapdefinition is created, but the layer I have just added isn't in it.
Someone know why?
Frédéric LIETO
URL: http://lists.osgeo.org/pipermail/mapguide_dev/attachments/20060601/f0e25d26/attachment.html
More information about the Mapguide_dev
