[mapguide-dev] Fw: Autodesk MapGuide Studio and WebStudio?
Andy Morsell amorsell at spatialgis.com
Tue Nov 7 11:07:43 EST 2006
Or, if you installed on Windows Internet Information Services instead of
Apache, there would be no port number and your URL would be:
http://localhost/mapguide
Andy
-----Original Message-----
From: Paul Spencer [mailto:pspencer at dmsolutions.ca]
Sent: Tuesday, November 07, 2006 5:09 AM
To: dev at mapguide.osgeo.org
Subject: Re: [mapguide-dev] Fw: Autodesk MapGuide Studio and WebStudio?
Alba,
you need to log into a mapguide server.
Site: the site is a url to your mapguide server.  This is in the form of
http://<ip-of-mapguide-server>:<port>/mapguide/
If you are running Studio ON THE SAME MACHINE as you installed MapGuide, and
you didn't change any defaults during MapGuide installation, the url will be
http://localhost:8008/mapguide
If you are running Studio on a different machine, you need to know the IP
address or host name of the machine you installed on.
User Id will typically be Administrator for a default installation
Password is admin for a default installation.
So to summarize:
site: http://localhost:8008/mapguide
user: Administrator
pass: admin
Cheers
Paul
On 7-Nov-06, at 7:28 AM, alba wrote:
> Hi Paul
> Thank for your answer
> but when I execute some step  1)  or 2)......
> I got a dialog box : Site Authentication
>                            Log on to a Mapguide Site
>                            Site : null
>                            User Id : null
>                            Password: null What is it?
> Thank Alba
> View this message in context: http://www.nabble.com/Fw%3A-Autodesk-
> MapGuide-Studio-and-WebStudio--tf2587622.html#a7217447
> Sent from the MapGuide Dev mailing list archive at Nabble.com.
> To unsubscribe, e-mail: dev-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: dev-help at mapguide.osgeo.org
|Paul Spencer                          pspencer at dmsolutions.ca    |
|Chief Technology Officer                                         |
|DM Solutions Group Inc                http://www.dmsolutions.ca/ |
More information about the Mapguide_dev mailing list
