[mapguide-dev] Enhanced Join Support RFC
Ronnie Louie
ronnie.louie at autodesk.com
Wed Nov 8 12:38:23 EST 2006
Hi Jason,
Thanks for your comments. Your suggestions for handling 1:many are duly
noted, however it is not proposed as part of this RFC. As Bob mentioned
earlier in a previous email, the join functionality is implemented via a
Join component which is also shared with another commercially available
product. Changes were discussed to support "associations" of a primary
feature record to a set of secondary records, but ultimately did not
make it into that product's release cycle. I can only speculate that
this support may be part of a future release. As a result, MapGuide
will be restricted, for now, to the "lazy join" result for the 1:many
case.
As for your question on the SDF joins, it should be possible to join
secondary table to a primary table in the same SDF or different SDF
file. I haven't personally tested this, but if you've got SDFs with
multiple tables, you should be able to see a list of all the available
feature classes in the Studio Join UI for which you can use to define
you join.
Ronnie
_____
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Friday, November 03, 2006 4:21 PM
To: dev at mapguide.osgeo.org
Subject: RE: [mapguide-dev] Enhanced Join Support RFC
Overall, I like this proposal. I think that the 1:many support is
probably a good first step. It makes it easier to query secondary data
sources and return geometry.
However, it is really just a right outer join, and does not provide for
some of the most common map operations that will be required with 1:Many
relationships.
In particular, it will not be able to support maptips (display all
owners for a parcel), queries (only show properties with more than one
service connection) and theming (color ramp based on number of calls for
service)
I think that this would be best dealt with in two ways. First, I would
like to see an option to return a single geometry row, with a nested
rowset representing the "Many" records. Second, I would like to see the
option to return a single geometry row along with some basic aggregate
(sum, min, max, mean, group_concat) and search (contains) results,
essentially acting as a GROUP BY operator on the root geometry. These
could even be combined, allowing both the aggregate functions and the
nested results to be returned.
I understand that this is a big request, but I thought I'd reiterate it
here. It was discussed in IRC after the last meeting, but I don't have
the logs.
I also have a question about why spatial and aspatial data sources are
so segregated in Studio. I may just be a bit fuzzy, but is it possible
to join a secondary table in an SDF file to a primary table in the same
SDF file? In another SDF file?
Jason
_____
Sent: Fri 2006-11-03 2:48 PM
Subject: [mapguide-dev] Enhanced Join Support RFC
Hi All,
A first draft of Enhanced Join Support RFC for MGOS is posted at
http://wiki.osgeo.org/index.php/MapGuide_RFC_5_-_Enhanced_Join_Support.
Please have a look and post your feedback to this group.
Thanks
Ronnie Louie
URL: http://lists.osgeo.org/pipermail/mapguide_dev/attachments/20061108/5fa7ceea/attachment.html
More information about the Mapguide_dev
