[mapguide-dev] Unmanaged Data APIs RFC
Zak James zjames at dmsolutions.ca
Wed Nov 8 23:10:33 EST 2006
Tom,
I think we will definitely be supporting the new API once it's
available, but in light of what you've said, the current approach is
still valid and I don't see a reason to stop users from creating
feature sources from unmapped data sources.
Thanks for the clarification.
zak
Zak James
Applications and Software Development
DM Solutions Group Inc.
http://www.dmsolutions.ca
On 8 Nov 2006, at 23:03, Tom Fukushima wrote:
> Hi Zak,
> I don't want to lock down the server so that it is restricted to those
> files in the Unmanaged Data Mappings. In other words, this means
> that a
> feature source can still reference a file that is not in one of the
> subdirectories specified by the mappings. The reason we don't have to
> restrict to those subdirectories is because we can use the operating
> system's or network's built-in security to limit access to files
> (hopefully they've allowed access to the files in the Unmanaged Data,
> otherwise they won't be very useful :) ).
> Will WebStudio use the new APIs instead of allowing the enumeration of
> arbitrary directories?
> Tom
> -----Original Message-----
> From: Zak James [mailto:zjames at dmsolutions.ca]
> Sent: Friday, November 03, 2006 9:15 PM
> To: dev at mapguide.osgeo.org
> Subject: Re: [mapguide-dev] Unmanaged Data APIs RFC
> This is a minor compatibility issue, but the current version of
> webstudio allows the user to specify an unmanaged feature source
> with an
> arbitrary server path and then enumerates files in that path.
> Obviously, there are some security issues with this, but is that
> functionality going to disappear with the changes proposed in the RFC?
> If so, I think that needs to be stated in the Proposed Changes
> section.
> zak
> Zak James
> On 3 Nov 2006, at 20:57, Jason Birch wrote:
>> Looks good.
>> I would personally prefer to see a single delimiter in the returned
>> list, as it's slightly easier to deal with in code.
>> I'm probably overly sensitive to this, but I'm wondering if the
>> resource list will be cached on the server?  I know that the 6.5
>> MapGuide author caches the responses internally.  I have to hit
>> "update" to get a new list if something (data store, feature source,
>> feature source schema) changes in the current session.  Can we count
>> on the clients doing this to prevent unnecessary network traffic
>> re-enumerating the resources?
>> Jason
>> ________________________________
>> From: Tony Fang [mailto:tony.fang at autodesk.com]
>> Sent: Fri 2006-11-03 4:41 PM
>> Subject: RE: [mapguide-dev] Unmanaged Data APIs RFC
>> I've updated the RFC with the drive mappings suggestion. Any feedback
>> on the returned list of drive mappings (using square brackets on the
>> drive mapping name) would be appreciated.
>> The server's unmanaged data directories will be specified using the
>> serverconfig.ini. A new section defining directory mappings will be
>> used to specify the unmanaged data directories.
>> For windows, it may look like this:
>> [Unmanaged Data Mappings]
>> SomeSdfFiles = c:\mydata\sdf
>> Some Shp Files = d:\otherdata\shp
>> BigArseImages = \\some_other_machine\data\images
>> Some ???? DwfFiles = c:\mydata\????Dwf
>> ??sdf = c:\mydata\bigsdf
>> For linux, it may look like this:
>> SomeSdfFiles = /usr/mydata/sdf
>> Some Shp Files = /usr/otherdata/shp
>> BigArseImages = /mnt/some_other_machine/data/images
>> Some ???? DwfFiles = /usr/mydata/????Dwf
>> ??sdf = /usr/mydata/bigsdf
>> Unicode characters are supported in the mapping names. Spaces in
>> the mappings are also supported. Square brackets [ and ] are not
>> allowed. They are reserved characters for the serverconfig.ini
>> section titles.
>> We will add API methods to return the unmanaged data mappings, set
>> the mappings, and also verify that the mappings are valid and
>> accessible.
>> We will add an API to enumerate the unmanaged data files available
>> on the server machine. The files will be prefaced with their
>> mapping names. You may enumerate all files from all the available
>> drive mappings, or you may select a single drive mapping.
>> A returned list from all available drive mappings may look like this:
>> [SomeSdfFiles]world.sdf
>> [Some Shp Files]ecuador.shp
>> [Some ???? DwfFiles]large.dwf
>> [Some ???? DwfFiles]subdir/Big.dwf
>> [??sdf]reallybig.sdf
>> Thanks,
>> Tony
>> From: Robert Bray [mailto:rbray at robertbray.net]
>> Sent: Friday, November 03, 2006 9:05 AM
>> Jason,
>> Good questions. In addition I think it would make sense / be highly
>> desirable for all RFCs that add or modify APIs to include more
>> detail with respect to those changes. It would be nice to see the
>> actual API function signatures for example.
>> Bob
>> Jason Birch wrote:
>> That would be cool.  That way we can have a theme, and a nested
>> hierarchy within that theme if we need the complexity.  Are we
>> restricted to single-word mappings, or will spaces be supported?
>> ASCII characters only or full internationalisation?
>> What about schema changes?  Will there be a way of updating the
>> repository's knowledge of unmanaged data schemae?  Or are these
>> maybe cached on a session basis like the RDBMS schemae?
>> There would also need to be a method that allows the author UIs to
>> validate resources that reference unmanaged data sources, to make
>> sure that any dependancies (properties, maptips, themes, etc) are
>> still valid, and give a graphical indication when the world slips.
>> Jason
>> Sent: Thu 2006-11-02 10:46 PM
>> I too am concerned this will make data management hard for people
>> with lots of data / multiple projects. It might be better to
>> dedicate a section in serverconfig.ini to define path mappings as
>> follows:
>> [Path Mappings]
>> SomeSdfFiles = <some path>
>> SomeShpFiles = <some other path>
>> BigArseImages = <path to SAN disk>
>> In Studio / Web Studio the user would be presented the list of path
>> mappings. Once they select a path mapping they can browse all files
>> and folders below that path.
>> My 2 cents...
>> Bob
>> To unsubscribe, e-mail: dev-unsubscribe at mapguide.osgeo.org For
>> additional commands, e-mail: dev-help at mapguide.osgeo.org
>> <winmail.dat>
>> For additional commands, e-mail: dev-help at mapguide.osgeo.org
More information about the Mapguide_dev mailing list
