[mapguide-dev] Coordinate Conversion operations in MapAgent?
Paul Spencer
pspencer at dmsolutions.ca
Thu Oct 5 12:53:28 EDT 2006
Thanks Bruce. I can probably figure out the php api but your
examples would be great if you can send them along.
For WebStudio, we are trying to keep it clean of server-side code so
that it can be installed/run from anywhere. Do you think there is a
possibility of adding coordinate transformation code to the mapagent?
I'd be willing to help document and test it, but I don't have the
skill to actually do it :)
Cheers
Paul
Begin forwarded message:
> From: "Bruce Dechant" <bruce.dechant at autodesk.com>
> Date: 5 October 2006 10:48:07 GMT-04:00
> To: <dev at mapguide.osgeo.org>
> Subject: RE: [mapguide-dev] Coordinate Conversion operations in
> MapAgent?
> Reply-To: dev at mapguide.osgeo.org
> Paul,
> You can access the coordinate system API through any of the supported
> languages (PHP/JAVA/.NET). However, there is currently no way to
> access
> the coordinate system API directly using HTTP requests.
> In the up coming service pack release of MapGuide I added some
> coordinate system test pages to the web tier test pages. These are
> done
> in PHP. If you want I can send them to you early if you want to take a
> look.
> Bruce
> -----Original Message-----
> From: Paul Spencer (External)
> Sent: October 5, 2006 8:14 AM
> Subject: [mapguide-dev] Coordinate Conversion operations in MapAgent?
> MapGuide dev guys ... is there any capability to to access the
> coordinate conversion library through mapagent?
> My goal is to be able to work with the Map extents in Web Studio and
> set the extents based on the layer extent(s). The problematic case
> is the one where a layer's coordinate system is different from the
> map's coordinate system ...
> One option is to add an optional parameter to GetSpatialContexts
> which would be another coordinate system (in this case, the
> MapDefinition coordinate system).
> The other would be to expose conversion of wkt geometries between wkt
> coordinate systems as a new operation in mapagent.
> All of the required functionality exists in the API as far as I can
> tell.
> Cheers
> Paul
> |Paul Spencer pspencer at dmsolutions.ca |
> |Chief Technology Officer |
> |DM Solutions Group Inc http://www.dmsolutions.ca/|
> To unsubscribe, e-mail: dev-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: dev-help at mapguide.osgeo.org
More information about the Mapguide_dev
