[mapguide-dev] Labels showing through overlaying polygons?
Jason Birch Jason.Birch at nanaimo.ca
Sun Oct 29 03:02:56 EST 2006
Somebody's up late :)
Yes, it's the way that 6.5 worked, and it's annoying there too... you
guys did awesome with Tux though, most of my other annoyances were dealt
with.
The attached screenshot shows the problem.
Jason
-----Original Message-----
Sent: Sunday, October 29, 2006 00:33
To: dev at mapguide.osgeo.org
Subject: Re: [mapguide-dev] Labels showing through overlaying polygons?
Well I guess it could be either one. Unless my memory is failing me
miserably MapGuide 6.x behaves the exact same way. The general labeling
logic was derived from the predecessor, hence the behavior is the same.
I suspect the right behavior would be to use the polygons as an
exclusion list for all layers with labels below it in the draw order.
Bob
Jason Birch wrote:
> Hi,
> I'm seeing the behaviour that a label for a line that is covered by a
> polygon on another layer is being displayed over top of that polygon.
> Is this intended behaviour (enhancement request for collision
> handling) or a bug (defect report)?
> Thanks,
> Jason
> To unsubscribe, e-mail: dev-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: dev-help at mapguide.osgeo.org
Type: image/jpeg
Desc: label_outofplace.jpg
Url : http://lists.osgeo.org/pipermail/mapguide_dev/attachments/20061029/031ab611/label_outofplace.jpg
More information about the Mapguide_dev mailing list
