[mapguide-dev] RE: [mapguide-psc] MapGuide's 1st RFC!
Traian Stanev
traian.stanev at autodesk.com
Tue Oct 31 22:51:20 EST 2006
Or, you can drop the - and / altogether and have something like:
mgserver start
mgserver stop
mgserver run
etc.
This would be similar to the apache command line, the subversion command line client, the ifconfig tool on Linux, the net command on Windows, etc., etc.
Traian
-----Original Message-----
Sent: Tue 10/31/2006 10:22 PM
To: psc at mapguide.osgeo.org; dev at mapguide.osgeo.org
Cc:
Subject: [mapguide-dev] RE: [mapguide-psc] MapGuide's 1st RFC!
Yes, I would like to see both formats ("/" and "-") supported as well.
But when the user gets the command line help by typing "mgserver -?" or
"mgserver --help" (note the double dash), I propose that we only show
the "-" versions of the options. Of course, this is a bit confusing to
those users who want to figure out what /interactive means; Bruce, why
are we changing "interactive" to "run"? Or will "mgserver -interactive"
also work?
So typing "mgserver --help" outputs:
The following is a list of supported command line options:
-? or --help
Displays this information.
-install <Name>
Installs the server as a service. Automatically starts the
service.
Default service display name installed:
"MapGuide Server"
You can use a different display name for the service if you
specify an
optional "Name".
-run
Runs the server interactively as an application instead of a
service.
-start
Starts the server service. Note: The service must be installed.
-stop
Stops the server service. Note: The service must be installed.
-testfdo <Filename>
Runs the FDO unit tests.
Default output of the FDO unit tests will be the console unless
you
specify an optional "Filename". The output to the "Filename" will
be
in XML.
-test <Test> /o <Filename>
Runs the server unit tests.
By default all of the unit tests will be run unless you specify an
optional "Test" to run. If you specify "List" as the test to run
you
will get a list of the available unit tests.
Default output of the unit tests will be the console unless you
specify
an optional "Filename". The output to the "Filename" will be in
XML.
-uninstall
Uninstalls an installed server service. Automatically stops the
service
before uninstalling.
Note: Only 1 command line option can be used at a time.
Sent: Tuesday, October 31, 2006 2:49 PM
Subject: RE: [mapguide-psc] MapGuide's 1st RFC!
I will be easy enough to support both. I'll update the RFC to reflect
this.
Bruce
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: October 31, 2006 12:42 PM
I agree, it's probably not a big issue. It depends on how much work it
would be on Bruce's end to support backwards compatibility. If it would
be relatively easy, then may as well do it. If it would require a large
effort, then the current console response to an incorrect parameter
should be sufficient for users to figure it out on their own.
Andy
From: Paul Spencer [mailto:pspencer at dmsolutions.ca]
Sent: Tuesday, October 31, 2006 11:29 AM
Subject: Re: [mapguide-psc] MapGuide's 1st RFC!
I am normally a big fan of backwards compatibility too, but I really
don't see this as a big issue. Perhaps if the tool just spits out an
appropriate message if called with incorrect parameters?
Then again, windows users are most likely used to the / style of adding
parameters so perhaps that makes it worthwhile supporting both?
Paul
On 31-Oct-06, at 2:08 PM, Andy Morsell wrote:
> I agree with Frank in that keeping it backwards compatible with the
> older command line parameters while in the future only documenting the
> new ones would be the best. There are many references, mostly in
> archived messages in the mapguide-users mailing list, to the current
> parameter syntax that new users are bound to run across (and try to
> use) when doing research.
> Regarding the RFC format, that seems to work very well.
> Andy
> From: Bruce Dechant [mailto:bruce.dechant at autodesk.com]
> Sent: Tuesday, October 31, 2006 10:20 AM
> Subject: [mapguide-psc] MapGuide's 1st RFC!
> Hi All,
> I wrote up a simple MapGuide RFC to give our process a trial run.
> http://wiki.osgeo.org/index.php/MG_RFC_1_-
> _Commandline_parameter_changes
> Please have a look and post any feedback.
> Thanks,
> Bruce
|Paul Spencer pspencer at dmsolutions.ca |
|Chief Technology Officer |
|DM Solutions Group Inc http://www.dmsolutions.ca/ |
To unsubscribe, e-mail: dev-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: dev-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide_dev/attachments/20061031/a549cdf3/attachment.html
More information about the Mapguide_dev
