[mapguide-dev] Data re-projection
Bruce Dechant bruce.dechant at autodesk.com
Fri Sep 15 12:12:20 EDT 2006
Ricard,
MapGuide already does this. If the "Map" is in one coordinate system and
any of your "Layers" are in a different coordinate system the data will
be re-projected if required to the coordinate system used by the "Map".
Bruce
  _____
From: Ricard Grau (Yahoo) [mailto:ricardgrau at yahoo.es]
Sent: September 13, 2006 8:35 AM
To: dev at mapguide.osgeo.org
Subject: [mapguide-dev] Data re-projection
Hi all,
Anybody knows if exists any MapGuide development to automatically
transpose Vector and Raster data by changing the coordinate system? For
example from ED50-UTMXX to WGS84?
In the European countries, when European Union Inspire's Directive will
be active, with independency of the coordinate systems in the source
data all the Clients or Web application will must to offer the spatial
information in a specific coordinate systems.
Regards
Ricard
URL: http://lists.osgeo.org/pipermail/mapguide_dev/attachments/20060915/5b7f49a1/attachment.html
More information about the Mapguide_dev mailing list
