[mapguide-dev] Metadata
Paul Spencer
pspencer at dmsolutions.ca
Mon Sep 18 17:12:38 EDT 2006
Jason,
I suspect that the metadata system they are putting in is more in the
line of free-form storage system associated with a resource rather
than a structured metadata standard (FGDC?) which you seem to think
this is. I could be wrong :)
For instance, the description of the MapDefinition that you enter in
Studio is stored in a metadata tag inside the actual XML
representation of the MapDefinition.
I think you raise an excellent point, though. It could be very
compelling to have a real metadata capability inside MapGuide.
Cheers
Paul
On 18-Sep-06, at 4:17 PM, Jason Birch wrote:
> Hi all,
> I am concerned that by just storing Metadata as an XML chunk against
> resources, that it will be extremely difficult to manage on an
> enterprise level. I may just be getting worked up about something
> that
> has already been considered but...
> A good metadata system should store at least organisation and contact
> information independently, taking advantage of a relational model and
> making maintenance easier. Meta information stored against data sets
> should be composited on the fly into the required metadata standard.
> As well, metadata should not be limited to the information stored
> directly in MapGuide. It should be possible to store metadata for
> external resources, including those referred to in load
> procedures. The
> metadata for the resultant data would then reference the source they
> were derived from.
> Hmm. On the flip side, there should at least be the ability to parse
> and load XML metadata in standard formats, such as generated by
> ArcGIS.
> Jason
> To unsubscribe, e-mail: dev-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: dev-help at mapguide.osgeo.org
|Paul Spencer pspencer at dmsolutions.ca |
|Applications & Software Development |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
More information about the Mapguide_dev
