[Mapguide_dev] MapGuide RFC 11 - Stateless Http GETTILEIMAGE
request
Trevor Wekel
trevor.wekel at autodesk.com
Mon Jan 8 19:25:30 EST 2007
Hi Jason,
I can add a message to the server log indicating when the cache has been
flushed.
MgMap generation can be costly if the FeatureSource and LayerDefinitions
have not been previously cached. For large maps, I have seen initial
MgMap createtimes in the 1 to 2 second range. If the
FeatureSource/LayerDefinition docs have been cached, the create time
will go down to roughly 0.2 seconds.
If you interested in calculating create times for your maps, take a look
at the response times for mapframe.php/jsp/aspx. This is where the
MgMap is initially constructed by the ajax viewer.
Thanks,
Trevor
_____
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Monday, January 08, 2007 5:12 PM
To: Trevor Wekel; mapguide_dev at lists.osgeo.org
Subject: RE: [Mapguide_dev] MapGuide RFC 11 - Stateless Http
GETTILEIMAGE request
I like this proposal.
Will there be a message written to the server log when the map cache is
flushed? I don't know if generating the MgMap objects is especially
costly, but on a site that has more than 10 tiled maps set up, it's
probably worth being able to see where some additional performance could
be squeezed out.
Jason
_____
[mailto:mapguide_dev-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel
Sent: Friday, January 05, 2007 16:16
To: mapguide_dev at lists.osgeo.org
Subject: [Mapguide_dev] MapGuide RFC 11 - Stateless Http GETTILEIMAGE
request
Hello Dev list,
I would like to submit the following RFC for review and discussion by
the community. Please post any comments back to the list and I will be
happy to respond.
http://wiki.osgeo.org/index.php/MapGuide_RFC_11_-_Stateless_Http_GETTILE
IMAGE_request
<http://wiki.osgeo.org/index.php/MapGuide_RFC_11_-_Stateless_Http_GETTIL
EIMAGE_request>
Thanks,
Trevor
URL: http://lists.osgeo.org/pipermail/mapguide_dev/attachments/20070108/e0faeb9d/attachment.html
More information about the Mapguide_dev
