[mapguide][MG178][New] Script error when previewing a themed DWG layer
Alain Lebatard alain.lebatard at autodesk.com
Mon Apr 3 16:46:27 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG178
Type
 Defect
Artifact ID
 MG178 (Script error when previewing a themed DWG layer)
Reported by
 Alain Lebatard
 alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Component set to new value
  Web Server Extensions
- Added file attachment
  FeatureDefFile.xml
  ClassifiedThemedWheatonVotingDistricts.dwg
- Steps to Reproduce set to new value
  In Studio, drop the attached DWG file on the site explorer, then click 'load resource' in the load procedure dialog.
Open the layer created
   -> Script error
- Summary set to new value
- Version set to new value
  1.0.0
- Artifact created
- Description set to new value
  The legend control script generates script errors when previewing a themed layer created from DWG
- Subcomponent set to new value
  General
- Defect Severity set to new value
  High
- Artifact Status set to new value
  New
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
