[mapguide][MG184][Modified] Fix nonlocalized string in buffer UI
Walt Welton-Lair walt.welton-lair at autodesk.com
Tue Apr 4 12:30:30 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG184
Type:
Defect
Artifact ID:
MG184 (Fix nonlocalized string in buffer UI)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Component set to new value:
Web Server Extensions
-- Resolution Description set to new value:
Code fix has been submitted.
-- Status Explanation set to new value:
-- Resolution set to new value:
Submitted
-- Artifact Status changed:
Old value:
Assigned
New value:
Resolved
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
