[mapguide][MG178][Modified] Script error when previewing a themed DWG layer
Alain Lebatard
alain.lebatard at autodesk.com
Tue Apr 4 12:44:17 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG178
Type:
Defect
Artifact ID:
MG178 (Script error when previewing a themed DWG layer)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
The bug was due to embedded quotes in quote-delimited strings, causing a syntax error in the generated client script.
-- Resolution set to new value:
Submitted
-- Artifact Status changed:
Old value:
New
New value:
Resolved
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
