[mapguide][MG185][New] Fixed problem with UI in Configure Server page of Site Admin...
Louise Watson
louise.watson at autodesk.com
Tue Apr 4 14:13:01 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG185
Type
Defect
Artifact ID
MG185 (Fixed problem with UI in Configure Server page of Site Admin with a support server)
Reported by
Louise Watson
louisewatson (louise.watson at autodesk.com)
New artifact details:
- Steps to Reproduce set to new value
1. Set up a Site Server and a Support Server.
2. Using Site Admin, add the Support Server to the Site.
3. Navigate to the "Configure Properties" page and select the support server.
4. Notice that the description field is small and unreadable.
- Priority set to new value
P1
- Resolution set to new value
Submitted
- Summary set to new value
- Artifact Status set to new value
New
- Version set to new value
1.0.0
- Artifact created
- Resolution Description set to new value
The fix was to assign the textarea control which displays the server description the inputFormValue style.
- Defect Severity set to new value
High
- Description set to new value
Testing with a support server revealed a UI problem with the "Configure Server" page of Site Admin. With support servers, the "Configure Server" page displays a description field. (This field is not shown with Site servers.) Anyway, the style of the textarea which displays the description was incorrect and the field was too small to display the description in a readable fashion.
- Target milestone set to new value
1.0.0
- Operating system set to new value
All
- Component set to new value
Web Server Extensions
- Subcomponent set to new value
Map Admin
- Build set to new value
169.1
- Status Explanation set to new value
The description field is very difficult to use as it currently displays.
- Platform set to new value
All
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
