[mapguide][MG187][Modified] Transparency in image symbols does not work in AJAX viewer
Traian Stanev traian.stanev at autodesk.com
Wed Apr 5 14:52:04 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG187
Type:
Defect
Artifact ID:
MG187 (Transparency in image symbols does not work in AJAX viewer)
Modified by:
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
Code fix.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
