[mapguide][MG188][New] Script error when changing scale before map is loaded in AJA...
    Alain Lebatard
    alain.lebatard at autodesk.com
    Wed Apr  5 18:16:12 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG188
Type
 Defect
Artifact ID
 MG188 (Script error when changing scale before map is loaded in AJAX viewer)
Reported by
 Alain Lebatard
 alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Description set to new value
  In a map that is slow to load, because it has complex layers for example, carrying map actions (such as changing the scale) before the map is loaded causes a script error.
- Platform set to new value
  All
- Subcomponent set to new value
  AJAX Viewer
- Steps to Reproduce set to new value
  Open a map with several layers.
As soon as the scale slider appear and before the map image is loaded, move the scale slider.
  => script error
- Artifact created
- Version set to new value
  1.0.0
- Defect Severity set to new value
  Medium
- Summary set to new value
- Artifact Status set to new value
  New
- Component set to new value
  Web Server Extensions
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
