[mapguide][MG191][New] Layer filter is ignored for DWF-based layers
Traian Stanev
traian.stanev at autodesk.com
Thu Apr 6 10:50:50 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG191
Type
Defect
Artifact ID
MG191 (Layer filter is ignored for DWF-based layers)
Reported by
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
New artifact details:
- Steps to Reproduce set to new value
Set up a DWF-based layer with a layer filter using Studio. The filter is ignored.
- Version set to new value
1.0.0
- Artifact created
- Platform set to new value
All
- Subcomponent set to new value
Mapping Service
- Artifact Status set to new value
New
- Component set to new value
Server
- Description set to new value
DWF-based layers are supposed to be able to filter which layers are extracted from the DWF via a filter string specified in the map definition. This is not working on the server side -- the given filter is ignored and all layers are always processed.
- Priority set to new value
P3
- Defect Severity set to new value
Medium
- Summary set to new value
- Operating system set to new value
All
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
