[mapguide][MG193][New] Server memory leak fixes
Walt Welton-Lair walt.welton-lair at autodesk.com
Thu Apr 6 12:10:19 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG193
Type
 Defect
Artifact ID
 MG193 (Server memory leak fixes)
Reported by
 Walt Welton-Lair
 waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- Steps to Reproduce set to new value
  Run the unit tests against a debug build of FDO.  You will see leaked objects dumped at the end.
- Summary set to new value
- Component set to new value
  Server
- Platform set to new value
  All
- Subcomponent set to new value
  Core
- Defect Severity set to new value
  High
- Priority set to new value
  P2
- Target milestone set to new value
  1.0.1
- Artifact created
- Artifact Status set to new value
  New
- Operating system set to new value
  All
- Description set to new value
  There are numerous places where the server code is not correctly refcounting FDO objects, resulting in leaks of those objects.
- Version set to new value
  1.0.0
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
