[mapguide][MG193][Modified] Server memory leak fixes
Walt Welton-Lair walt.welton-lair at autodesk.com
Thu Apr 6 13:03:14 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG193
Type:
Defect
Artifact ID:
MG193 (Server memory leak fixes)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Testing Notes set to new value:
All server unit tests were run against a debug build of FDO.  There are only a couple of leaks now, and those are in FDO.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
