[mapguide][MG194][New] Ensure EPlots correctly clip entities
    Walt Welton-Lair
    walt.welton-lair at autodesk.com
    Thu Apr  6 17:16:04 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG194
Type
 Defect
Artifact ID
 MG194 (Ensure EPlots correctly clip entities)
Reported by
 Walt Welton-Lair
 waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- Platform set to new value
  All
- Version set to new value
  1.0.0
- Description set to new value
  When using the DWF Viewer, if you generate an EPlot of a map containing labels you'll notice that labels will extend past the edge of the map.  This detracts significantly from the output quality.
- Operating system set to new value
  All
- Defect Severity set to new value
  High
- Summary set to new value
- Priority set to new value
  P2
- Steps to Reproduce set to new value
  1/ Open the Sheboygan map (sample application) and zoom in until the parcels are visible.
- Subcomponent set to new value
  Mapping Service
- Component set to new value
  Server
- Target milestone set to new value
  1.0.1
- Artifact Status set to new value
  New
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
