[mapguide][MG194][Modified] Ensure EPlots correctly clip entities
Walt Welton-Lair walt.welton-lair at autodesk.com
Thu Apr 6 17:29:20 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG194
Type:
Defect
Artifact ID:
MG194 (Ensure EPlots correctly clip entities)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
Code fix has been submitted.
-- Artifact Status changed:
Old value:
Assigned
New value:
Resolved
-- Status Explanation set to new value:
-- Developer Notes set to new value:
Part of this is the fault of the DWF Viewer.  The EPlot specification says you can supply a clip with the paper and nothing will br drawn outside this clip.  Unfortunately this behavior is not implemented in the DWF Viewer.
The workaround is to simply put the data for each layer into a viewport.
-- Resolution set to new value:
Submitted
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
