[mapguide][MG196][New] AJAX crashes with IE Script Error in layer/map preview of DW...
Alain Lebatard
alain.lebatard at autodesk.com
Thu Apr 6 19:55:18 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG196
Type
Defect
Artifact ID
MG196 (AJAX crashes with IE Script Error in layer/map preview of DWF from Mako)
Reported by
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Subcomponent set to new value
AJAX Viewer
- Steps to Reproduce set to new value
1. Load the attached DWF, NO-ExtentsMap Base.dwf.
This DWF was created by Mako's Publish to MapGuide.
2. Preview the layer and move the zoom slider.
RESULT: Internet Explorer Script error is displayed.
Attempting to dismiss the error is unsuccessful and eventually killing the Studio process is the only solution for getting on with your life.
- Summary set to new value
- Component set to new value
Web Server Extensions
- Description set to new value
- Artifact Status set to new value
New
- Added file attachment
NO-ExtentsMap_Base.dwf
- Artifact created
- Defect Severity set to new value
Critical
- Version set to new value
1.0.0
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
