[mapguide][MG197][New] DWFViewer incorrect symbols draw for themed point layers
Traian Stanev
traian.stanev at autodesk.com
Fri Apr 7 10:34:53 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG197
Type
Defect
Artifact ID
MG197 (DWFViewer incorrect symbols draw for themed point layers)
Reported by
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
New artifact details:
- Artifact created
- Subcomponent set to new value
Mapping Service
- Steps to Reproduce set to new value
a
- Defect Severity set to new value
Medium
- Description set to new value
This takes too long to reproduce, but the gist of it is that in certain combinations of DWF based and font based symbols, when theming is present for the point layer, some points will draw with the wrong size and symbol. The problem only happens in the DWF viewer, the AJAX viewer works fine.
- Component set to new value
Server
- Summary set to new value
- Platform set to new value
All
- Artifact Status set to new value
New
- Operating system set to new value
All
- Target milestone set to new value
1.0.1
- Priority set to new value
P2
- Version set to new value
1.0.0
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
