[mapguide][MG198][Modified] Site/Admin operations issue in license management infrastruc...
Ronnie Louie
ronnie.louie at autodesk.com
Fri Apr 7 12:12:33 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG198
Type:
Defect
Artifact ID:
MG198 (Site/Admin operations issue in license management infrastructure)
Modified by:
Ronnie Louie
ronnielouie (ronnie.louie at autodesk.com)
The following modifications were made to this artifact:
-- Target milestone set to new value:
1.0.0
-- Steps to Reproduce set to new value:
Old value:
No "real" licensing implementation, but an analysis of the infrastructure reveals that described scenario could potentially occur.
New value:
No "real" licensing implementation currently exists, but an analysis of the infrastructure reveals that described scenario could potentially occur.
-- Submission Reviewed set to new value:
No
-- Artifact Status changed:
Old value:
New
New value:
Assigned
-- Resolution Description set to new value:
Site/Admin operatations will be allowed to process without having to perform license check.
-- Related Artifacts set to new value:
MG161
-- Build set to new value:
169.5
-- Testing Notes set to new value:
Server unit tests: 379/379 tests OK
-- Summary changed:
Old value:
Potential issue with License Management Infrastructure
New value:
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
