[mapguide][MG201][New] Exception handlers in proxy do no catch access violation exc...
Alain Lebatard
alain.lebatard at autodesk.com
Fri Apr 7 17:25:54 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG201
Type
Defect
Artifact ID
MG201 (Exception handlers in proxy do no catch access violation exception)
Reported by
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Summary set to new value
- Component set to new value
Web Server Extensions
- Artifact created
- Version set to new value
1.0.0
- Defect Severity set to new value
Critical
- Artifact Status set to new value
New
- Steps to Reproduce set to new value
Execute the following code from a JSP script:
MgMapPlotCollection pcoll = new MgMapPlotCollection();
pcoll.Add(null);
=> Tomcat crashes (even if the sequence is put within a try/catch(MgException) statement)
- Description set to new value
The exception handlers in the proxy code catch C++ exceptions, but not Win32 access violation exception.
This is critical on the Java platform because such exception occuring in the MapGuide API cause Tomcat to crash.
- Subcomponent set to new value
Web API
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
