[mapguide][MG200][Modified] No error checking with map view parameters
Walt Welton-Lair walt.welton-lair at autodesk.com
Fri Apr 7 17:34:38 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG200
Type:
Defect
Artifact ID:
MG200 (No error checking with map view parameters)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
MG200
Modified
File: trunk/MgDev/Common/Service/Controller/Controller.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/Controller/Controller.cpp?view=diff&rev=447&p1=trunk/MgDev/Common/Service/Controller/Controller.cpp&r1=446&p2=trunk/MgDev/Common/Service/Controller/Controller.cpp&r2=447
File: trunk/MgDev/Common/Service/Controller/DwfController.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/Controller/DwfController.cpp?view=diff&rev=447&p1=trunk/MgDev/Common/Service/Controller/DwfController.cpp&r1=446&p2=trunk/MgDev/Common/Service/Controller/DwfController.cpp&r2=447
File: trunk/MgDev/Common/Service/Controller/HtmlController.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/Controller/HtmlController.cpp?view=diff&rev=447&p1=trunk/MgDev/Common/Service/Controller/HtmlController.cpp&r1=446&p2=trunk/MgDev/Common/Service/Controller/HtmlController.cpp&r2=447
File: trunk/MgDev/Common/Service/Exception/OutOfRangeException.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/Exception/OutOfRangeException.h?view=diff&rev=447&p1=trunk/MgDev/Common/Service/Exception/OutOfRangeException.h&r1=446&p2=trunk/MgDev/Common/Service/Exception/OutOfRangeException.h&r2=447
File: trunk/MgDev/Common/Service/MapLayer/Map.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/MapLayer/Map.cpp?view=diff&rev=447&p1=trunk/MgDev/Common/Service/MapLayer/Map.cpp&r1=446&p2=trunk/MgDev/Common/Service/MapLayer/Map.cpp&r2=447
File: trunk/MgDev/Server/src/Resources/server_en.res https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Resources/server_en.res?view=diff&rev=447&p1=trunk/MgDev/Server/src/Resources/server_en.res&r1=446&p2=trunk/MgDev/Server/src/Resources/server_en.res&r2=447
File: trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp?view=diff&rev=447&p1=trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp&r1=446&p2=trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp&r2=447
File: trunk/MgDev/Web/src/mapagent/Resources/web_en.res https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapagent/Resources/web_en.res?view=diff&rev=447&p1=trunk/MgDev/Web/src/mapagent/Resources/web_en.res&r1=446&p2=trunk/MgDev/Web/src/mapagent/Resources/web_en.res&r2=447
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
