[mapguide][MG203][Modified] Automatic removal of cached tile data
Steve Dang steve.dang at autodesk.com
Sun Apr 9 15:45:08 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG203
Type:
Defect
Artifact ID:
MG203 (Automatic removal of cached tile data)
Modified by:
Steve Dang
stevedang (steve.dang at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
Modified the EnumerateParentMapDefinitions method to handle dependencies from both Library and Session repositories.
Windows Server   unit tests failed/run: 0/379
Linux   Server   unit tests failed/run: 0/379
Windows Web Tier unit tests failed/run: 0/986
Modified
File: trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp?view=diff&rev=450&p1=trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp&r1=449&p2=trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp&r2=450
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
