[mapguide][MG204][New] Not all graphic resources returned by Drawing Service GetSec...
Traian Stanev traian.stanev at autodesk.com
Mon Apr 10 11:31:19 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG204
Type
 Defect
Artifact ID
 MG204 (Not all graphic resources returned by Drawing Service GetSection API)
Reported by
 Traian Stanev
 traianstanev (traian.stanev at autodesk.com)
New artifact details:
- Artifact Status set to new value
  New
- Artifact created
- Component set to new value
  Server
- Operating system set to new value
  All
- Description set to new value
  The GetSection() API of the drawing service only returned the primary graphic resource of the source section. It should return all resources, including non-graphic ones, since it is GetSection, not GetResource.
- Target milestone set to new value
  1.0.1
- Subcomponent set to new value
  Drawing Service
- Steps to Reproduce set to new value
  Create a drawing layer from a DWF which contains multiple graphic resources in a single section.
- Platform set to new value
  All
- Defect Severity set to new value
  High
- Version set to new value
  1.0.0
- Priority set to new value
  P2
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
