[mapguide][MG201][Modified] Exception handlers in proxy code do no catch access violatio...
Alain Lebatard alain.lebatard at autodesk.com
Mon Apr 10 16:40:18 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG201
Type:
Defect
Artifact ID:
MG201 (Exception handlers in proxy code do no catch access violation exception)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Resolution Description set to new value:
The C++ code was not compiled with the proper exception model. Compiler's option /EHs does not catch access violation exception.
This submission affects all the projects used by the web-tier and the server solutions. All these projects are now used the option /Eha
-- Resolution set to new value:
Submitted
-- Target milestone set to new value:
1.0.1
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
