[mapguide][MG206][New] WFS/WMS Unit Tests Operations Are Timing Out
Konstantin Nikolov konstantin.nikolov at autodesk.com
Mon Apr 10 21:01:16 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG206
Type
 Defect
Artifact ID
 MG206 (WFS/WMS Unit Tests Operations Are Timing Out)
Reported by
 Konstantin Nikolov
 konstantinnikolov (konstantin.nikolov at autodesk.com)
New artifact details:
- Artifact created
- Submission Reviewed set to new value
  No
- Summary set to new value
- Artifact Status set to new value
  New
- Defect Severity set to new value
  Low
- Version set to new value
  1.0.0
- Resolution set to new value
  Submitted
- Priority set to new value
  P4
- Description set to new value
  The WFS/WMS HTTP operations are causing CGI timeout on the unit test machine. Unable to reproduce the problem on local machine (Windows XP SP2, IIS 5.1)
- Resolution Description set to new value
  Commented the WFS/WMS operations for now.
- Steps to Reproduce set to new value
  Run WebExtensions unit tests.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
