[mapguide][MG207][New] Fix Unicode web-tier unit tests
Walt Welton-Lair
walt.welton-lair at autodesk.com
Mon Apr 10 22:20:00 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG207
Type
Defect
Artifact ID
MG207 (Fix Unicode web-tier unit tests)
Reported by
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- Artifact Status set to new value
New
- Platform set to new value
All
- Version set to new value
1.0.0
- Priority set to new value
P4
- Operating system set to new value
All
- Subcomponent set to new value
General
- Target milestone set to new value
1.0.1
- Steps to Reproduce set to new value
The web tier unit test suite currently doesn't run the unicode tests.
- Artifact created
- Defect Severity set to new value
Low
- Component set to new value
Web Server Extensions
- Summary set to new value
- Description set to new value
The unicode web tier unit tests have been commented out for a long time. They should really be part of the test suite to help exercise our code with strings containing multi-byte unicode characters.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
