[mapguide][MG209][New] Fix DWF Composer product name
Walt Welton-Lair walt.welton-lair at autodesk.com
Tue Apr 11 11:13:52 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG209
Type
 Defect
Artifact ID
 MG209 (Fix DWF Composer product name)
Reported by
 Walt Welton-Lair
 waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- Description set to new value
  The client-side code for DWF checks whether you have either DWF Viewer or DWF Composer installed, and instantiates the event relayer control using the appropriate CLSID.  It does this check by looking at the product name.  For the Amazon release of DWF, Composer has been renamed to Autodesk Design Review, and the product name reflects that.
Our script simply needs to be updated to use the new name.
- Defect Severity set to new value
  Critical
- Version set to new value
  1.0.0
- Priority set to new value
  P1
- Platform set to new value
  All
- Artifact Status set to new value
  New
- Summary set to new value
- Operating system set to new value
  All
- Subcomponent set to new value
  DWF Viewer
- Component set to new value
  Viewer
- Steps to Reproduce set to new value
  Install ADR and open a DWF-based web layout.  You'll get a script error.
- Artifact created
- Target milestone set to new value
  1.0.1
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
