[mapguide][MG211][New] Cancel function is not working in Buffer pane.
Alain Lebatard alain.lebatard at autodesk.com
Tue Apr 11 17:26:29 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG211
Type
 Defect
Artifact ID
 MG211 (Cancel function is not working in Buffer pane.)
Reported by
 Alain Lebatard
 alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Version set to new value
  1.0.0
- Defect Severity set to new value
  High
- Artifact created
- Subcomponent set to new value
  Viewer Command
- Steps to Reproduce set to new value
  1. Open Shebyogan with AJAX or DWF Viewer
2. Zoom into some area and select som objects such as parcel/building.
3. Select buffer from toolbar.
4. Verify "Layers to include in the butter=parcels"
5. Click on 'CANCEL' button
Problem: Cancel button function is not working.  Result shows as "buffer 1 has been created".
- Summary set to new value
- Component set to new value
  Web Server Extensions
- Artifact Status set to new value
  New
- Description set to new value
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
