[mapguide][MG210][Modified] Fix more server leaks
Walt Welton-Lair walt.welton-lair at autodesk.com
Wed Apr 12 11:38:14 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG210
Type:
Defect
Artifact ID:
MG210 (Fix more server leaks)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
MG210
Modified
File: trunk/MgDev/Common/Service/Services/Command.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/Services/Command.cpp?view=diff&rev=467&p1=trunk/MgDev/Common/Service/Services/Command.cpp&r1=466&p2=trunk/MgDev/Common/Service/Services/Command.cpp&r2=467
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
